werni9
Sep 04, 2014Explorer
antifreeze gone, oil thin
Oil and filter change and drove 38 miles to home and parked for a month. Went to check fluids and the antifreeze level was empty in the top reservoir. Put one gallon Fleet antifreeze in and then a second and then a gallon of distilled water. Just drank it down. It has never used any fluid to have to top off. I believe it may be empty. Checked the oil and it was light colored like new oil and it was right at the FULL mark. Oil consistency did not feel right. Felt thin. It moved down the stick quicker than normal. I took a quart out of the drain oil pan. It was darker, but no bubbles, no pink antifreeze came out. The oil is in a mason jar and has not settled out. Looks like oil should. If I had lost 7 or 8 gallons of antifreeze into the oil, the dip stick should have showed it well over FULL. I dropped my oil sample off at a Cat dealer for an oil analysis. I have a Cat 330 diesel. It is the 3126-B engine. Any ideas? Major fluid leak may have happened on the interstate? I had no warning lights. Oil pressure was fine and Engine Temp was normal. No alarms going off and just parked her. Started it back up 30 days later and oil pressure came up fine, but I got a LOW WATER LIGHT. That is when I noticed the reservoir empty. I am open for any ideas. There is no antifreeze under the coach. I am on good gravel, but it all looks fine. Maybe a hose? Maybe a water pump? Radiator and hoses and new antifreeze about 35,000 miles ago. Anything set off alarms to you? Thank you.............NO signs of a leak under the coach or around radiator area.
