wolfe10
Aug 27, 2013Explorer
JimM68 wrote:Blaster Man wrote:
I never fill the radiator with what I think is 50% of the capacity with coolant. If you think it is 9 gallons, get 9 gallon milk jugs and fill each with a 50/50 mixture. Then start filling the radiator with them. If the actual capacity is 7...you still have a 50/50 mixture in the radiator. If the actual capacity is 11, keep making gallons of 50/50 until it is full. What ever you have left, which isn't much, carry as extra in case you need it, and the radiator has exacty a 50/50 mixture.
I gotta say....
I've never read on the internet anything that makes that much sense.
Makes sense to me to, IF (read that very big IF) you are sure you have drained the system 100%. Ain't going to happen with a DP without a lot of extra work. 50' or so of heater hose from engine to dash heater plus heater core will not drain just because you opened the radiator drain.
38,776 PostsLatest Activity: May 14, 2026
