wolfe10
Aug 27, 2013Explorer
Don,
Yes there are test strips available-- most are three way and test pH, freeze point and SCA concentration. Make sure they are still indate, as they have a reasonably short shelf life and are not accurate if expired.
Here is an excellent Caterpillar document on fluids-- the section on coolants is near the end: http://parts.cat.com/cda/files/3244668/7/SEBU6385-08%20secure.pdf
On page 62:
62
SEBU6385-08
Maintenance Section
Cooling System Specifications i03260540
Extended Life Coolant Cooling System Maintenance
SMCS Code: 1350; 1352; 1395
Proper Additions to the Cat ELC (Extended Life Coolant)
NOTICE
Use only Cat products or commercial products that have passed the Caterpillar EC-1 specification for pre-mixed or concentrated coolants.
Use only Cat ELC Extender with Cat ELC. Do NOT use conventional SCA with Cat ELC. Mixing Cat ELC with conventional coolants and/or conventional SCA reduces the Cat ELC service life.
Do NOT mix brands or types of coolant. Do NOT mix brands or types of SCA and/or brands or types of extenders. Different brands or types may use different additive packages to meet the cooling system requirements. Different brands or types may not be compatible.
Do not mix brands or types of coolants with different brands or types of SCA or extender. Cat Extender is compatible with Cat ELC. If using non Cat EC-1 coolant, refer to the coolant manufacturer for information on a compatible extender.
Failure to follow the recommendations can reduce cooling system component life unless appropriate corrective action is performed.
On page 62:
62
SEBU6385-08
Maintenance Section
NOTICE
38,776 PostsLatest Activity: May 14, 2026
