Gjac
May 13, 2020Explorer III
The best advice I can give you is don't just replace the gasket, replace the exhaust manifolds with headers. If you look very carefully the stock manifolds are probably cracked anyways. The old 454's and 460's run hot anyways and tend to crack and burn spark plug wires also. I would also replace the ign wires with Hi temp 10.4 MM wires like the Taylor Extreme wires while you are at it. Your engine will run a lot cooler and the fan clutch will come on lest often, not to mention increasing your HP between 60 and 80 HP. If you plan to do the job yourself soak the bolts every day for a week with Kroil oil and tap each bolt head each day to set up a capillary action to get the oil into the threads. If the bolts won't come out or break off, I would let a garage do it.
38,782 PostsLatest Activity: Aug 31, 2026
