booster
Jul 25, 2017Explorer
Scott Malkinson wrote:
The charger acts like an isolator. It's a battery to battery charger. Promariner digital mobile charge 40. It monitors the starting battery and gives it priority. Once the starting battery is above the required volts it starts to charge the house batteries. Battery monitor is a xantrax linklite.
I just grabbed a quick look at the manual for the Promariner, and honestly, I think you will have trouble figuring out what it is up to at any given time, as it is constantly looking at things, primarily on the starting battery, and going on and off, up and down stages based on that voltage.
I also don't know how they can use the voltage of the starting battery to control anything because it is connected to the alternator and will be controlled by it's internal regulator. When the engine is running, it should always show charging voltage on the starting battery, which in vehicles is typically in the low 14s volts, but may be lower at high 13s volts.
From the description, it sounds like they are tailoring the charger to a small marine alternator, that will get dragged down by a 40 amp load, and likely is set to run at 13.8v or so. In a vehicle, you will have much higher current available, so it won't get the voltage dragged down by a 40 amp load, so all the prioritizing of batteries based on charge rates and the starting battery voltage gets to be a mute point, and probably causing more problems than solving them.
If my assumptions are correct, this may not be the best charger for your system. I am a fan of battery to battery chargers, but most of them I have looked at operate differently, it appears.
Basically, as you have plenty of amps available from the alternator, you should see charge voltage and the charger maxed out whenever the engine is running and either of the batteries is low. That voltage will be whatever the internal regulator in the alternator (or vehicle ECU) chooses for the starting battery, and whatever the charger chooses for the coach battery. The amp split will depend on how much they will accept relative to each other.
How long that charge voltage stays on each battery will depend on how the alternator regulator or the ECU turn down, or not, for the starting battery, and what the charger thinks is right for the coach battery based on it's internal algorithm for time. Since the charger is not connected to the monitor shunt, it will have really no accurate idea of the amps to the battery, and it didn't appear it will even know how big the battery is, so how good the charging actually is for getting the battery full without overcharging will likely not be stellar.
I think I would call Promariner and see what they say, although they likely will say all is good and don't worry about it (typical response by charger companies of all stripes). You could also call someone like Sterling and describe what you want to do, and see what they say about it, and how their products would handle it and be monitored.
It is a tough one to figure out what is going on without seeing it in person, and even seeing it might not shed much light with it's constant changing of parameters.
38,782 PostsLatest Activity: Sep 10, 2026
