valhalla360
Jan 19, 2022Navigator
Obviously if the 30amp outlet is in bad shape or there is a big difference in voltage, it's probably safer to use a good condition 50amp outlet with adapter.
But if both appear to be in good shape, there is a minor issue in that the circuit won't be protected by a 30 amp breaker. If you limit yourself to the continuous 24amp rating (note 30amp is a peak load, you only get 80% for continuous), it should be fine but if you get silly and try drawing 35-40amps, you will be overloading parts of your electrical system but the breaker on the pedestal won't trip.
38,782 PostsLatest Activity: Sep 10, 2026
