dougrainer
Jan 20, 2022Nomad
Durb wrote:
The 50 amp receptacle needs to draw 50+ amps in order to trip, whereas the 30 amp receptacle needs 30+ amps to trip. The #10 wire in your cord isn't designed to handle 50 amps so isn't protected. This is why they put #6 wire in 50 amp cords. Hopefully you have a 30 amp main disconnect in the trailer to help protect the cord running from the trailer to the pedestal. Many times people run off the 50 because the 30 is doing its job and tripping at the pedestal.
I too, often do this because my surge/voltage protection device is heavy and won't stay in the pedestal socket. Make sure you inspect your umbilical cord; black around the prong bases mean you are running hot.
Breaker/s are not a factor. Your interior MAIN 30 amp breaker will trip from any overload from the RV system. I also recommend using a 30 amp to 50 amp male plug if you have 50 amp Campground plug. This keeps the 30 amp Shore Cord end from overheating and melting and destroying the pins of the 30 amp end of cord from slight overloads on a 30 amp CG breaker. WE run 50 to 30 adapters all the time in our RV shop and NEVER have had any problem as the 30 amp RV main breaker WILL trip if we overload the RV. Doug
38,782 PostsLatest Activity: Sep 10, 2026
