Chum_lee
Jan 23, 2022Explorer
dodge guy wrote:
When we had he 30A TT I always pluggged into the 30A outlet. Over the many years of doing this there were a handful of times the breaker would pop. Then I bought a 50-30 adapter and always plugged into the 50A outlet. After doing that I never had a low voltage issue.
I recommend always plugging into the 50 if it’s available.
Agreed. I've found this to be the case several times too. As Doug says, your internal 30 amp main breaker should protect you. At aging parks, the pedestal breakers/plugs get a little worn/soft and IMO, that causes the 30 amp pedestal breaker to trip prematurely. Plugging into the 50 amp breaker with an adapter solves this problem. Some RV parks have undie bunching issues when you do this so it's advisable to check first. As always, MAKE SURE YOUR EQUIPMENT IS IN GOOD WORKING ORDER and not the cause of the problem.
Chum lee
38,782 PostsLatest Activity: Sep 10, 2026
