tenbear
May 09, 2014Explorer
Measuring the voltage across the fuse connectors doesn't mean much because the current drawn by the voltmeter is very low. So, if there is a small resistance to ground on the load side of the fuse, like a light bulb, the voltmeter will read the full voltage.
Here are links to some info about RV 12 volt systems. They might help you understand your RV electrical systems a little better
Understanding and maintaining your RVs 12 volt system.
The 12 volt side of life.
38,768 PostsLatest Activity: Nov 21, 2015
