tenbear
May 10, 2014Explorer
AFAIK the only way to know what is going on with the green circuit is to measure the current being drawn by it. A clamp-on ammeter is the easiest way but you could also do as I described earlier. You know it is not a dead short since the fuse doesn't blow. I guess you could try using smaller fuses and see what size fuse will blow. Do you know what is on this circuit other than lights?
Hope your shoulder improves. Been there, done that.
38,768 PostsLatest Activity: Nov 21, 2015
