Calisdad
May 28, 2014Explorer
Yes- thank you CA Traveler. It is the amp switch and it was early, I was just trying to post without getting up. I really don't see why I need a new charger.
tenbear the ammeter didn't get a reading because it didn't read below 1 amp. I'm really not following your statement that the 1.4v reading is meaningless. Are you saying current is NOT flowing thru the circuit? Because I did use an ammeter (albeit a cheap one) and it didn't give a reading one would have to assume it was less than the meters capabilities, or the meter didn't work- which it does (I tested it on an extension cord, separated and running a light bulb at the time).
38,769 PostsLatest Activity: Apr 04, 2026
