smlranger
Jan 31, 2017Explorer
The Safe T Plus is basically a hydraulic steering stabilizer. I had one on my previous coach, a 2002 36' DP on a FL chassis. It did seem to help the coach track better.
Before I would start putting things on, I would have a competent truck/bus suspension shop check alignment, condition of other front end components (sway bar bushings, end link bushings), grease the king pins, etc. Also, have you weighted the coach and adjusted your tire pressure to your actual load?
38,778 PostsLatest Activity: Jun 05, 2026
