doxiemom11
Feb 01, 2017Explorer II
If you have a Ford chassis, also consider the "cheap fix". We put new tires on, had an alignment, did the cheap fix front and rear and added the Saf-T-Plus. It all helped improve the handling.
I might add, if someone is fighting the Saf-T-Plus to drive, then it is not adjusted correctly. We did have to have minor adjustments right after installation before it was right. They will usually have you test drive it before you leave.
38,782 PostsLatest Activity: Sep 10, 2026
