dougrainer
May 27, 2016Nomad
The only real problem with the National Islander series was its front and rear cap so low to the ground. If you are not careful you will bottom out where regular Diesel's will not. Most Diesel's you can gently go up and down a curb if you need too. If you do the same thing in an Islander, you will damage the front or rear cap bottom. Doug
