JimBollman's avatar
JimBollman
Any Jayco B Owners Here
We bought a 1999 Jayco B built on a Ford E250 van. Great shape but needs lots of mods to be what we want. I quickly found out Jayco Bs are an orphan and the online info seems pretty scares.
I found a very short and not very helpful manual online but was hoping to find someone with a similar B that I could bounce questions off of that I think are specific to Jayco.
I have already remove the worthless toilet that was only usable if you're under 5'5" and 120lbs because of it's location. Was doubly worthless in that it was a basically a porta potty screwed to the floor that you had to use a stinky slinky to dump even though it had about the same capacity as a port-poty. It will be replaced with a porta=potty in a better location, or at least movable to a better location when we are stopped.
The battery is mounted underneath, haven't tried dropping it down yet, not sure what will happen when I take out what looks like the access bolt. I want to add a second battery and bigger batteries if possible.
JIm...
No RepliesBe the first to reply
