Mr.Mark wrote:
JetAonly wrote:
Deano56 wrote:
Someone had mentioned that it was sitting a lot since the mileage was at 30k, I guess that could mean rust underneath, specially if it was sitting on the gravel or dirt, I've seen what that can do first hand. I do not want rust, main reason why we go south to buy
Dynasty's of that vintage should be undercoated, mine is. FWIW, although the Monaco brand has changed hands a couple of times I have been able source everything either from the presently owned Monaco or the original vendors. The vendors that have gone under have functional equivalents. Ours has shrunk now that I have retired and we intend to replace it with an '05 or '06 Dynasty or above.
Well, if you want a little newer, I know of one that might fit the bill. You will not have to change out the TV's, etc.
MM.
Mr Mark, if I had a little more dollars to spend I would fly down there, sounds like you take good care of your purchases.
