Spizzer
Apr 03, 2015Explorer
smlranger wrote:
I've had the AF1 on two motorhomes and I ran a wire from the toad to the coach dash for the red LED indicator. I think the idea of putting the indicator light in the toad (mounted to the rear view mirror or somewhere on the toad's dashboard) is for folks who don't want to run the wire. I just wanted the indicator in the coach. Running the wire is not too bad, just takes time to do it and get it routed up to the coach dash. On my first DP, I got lucky and found an unused wire that ran from the rear to the area behind the brake pedal.
You are going to love the AF1. I was so happy to get rid of the dopey Apollo thing in the floorboard.
Thanks. I was thinking that might be the easiest method. Did you put the wire in one of your existing pins on the light hookups, or do you have a separate plug to connect each time?
jeff
38,766 PostsLatest Activity: Jan 10, 2026
