Spizzer
Apr 03, 2015Explorer
pigman1 wrote:
The seven pin connector has one pole that says BRAKE. This pole is already run to an unused wire under your RV dash where you could install a trailer brake controller. Hook your AF1 tow bar light to that pin, and get a 12V red LED you can put on your dash from Radio shack. Second leg of the LED goes to ground and you're done. I've done it on 3 AF1 installs on 3 different coaches.
Ah! I forgot about that. The PO actually had a brake controller mounted on the dash, which I removed. The wires are there. I'll double check it to make sure it is what I think it is. That sounds like an excellent way to do it. Thanks much!
jeff
38,766 PostsLatest Activity: Jan 10, 2026
