- squatting_dogExplorerI guess I'm also in the minority glass. We have owned all types of rv's covering the spectrum (cab over, class C, class A, bumper pull, fifth wheel, and finally a bus.) Currently have a class A again. Having been a journeyman diesel mechanic for 30+ years, I know the difference in costs for even the most basic items. (filters, oil amounts etc.). Now, factor in the cost of major items (engines, trans, rear ends) and I couldn't convince myself it was worth the extra cost. I hear people say all the time, "but,a diesel will go a million miles". True, but,how many people will put a million miles on an rv? These are not long haul truckers. Here's a simple test, hit a dealer and ask them how much for a set of plugs and a fuel pump and air filter for say a ford V10, then, hit Cummins and ask the same for injectors and an injector pump and air filter. These are common maintenance items. See what I mean?
Just my opinion... yours may be different. - HPYHILMExplorerI guess I'm in the minority. Very costly maintaining and very expensive break down repairs. You have no idea what a minor repair can set you back. I had gas MoHos with engine replacement that ran $5500. Lose a diesel genset and you would be happy just to pay the price to replace a gas engine. Just imagine replacing a tranny or engine on your diesel. Heck just and air dryer will set you back big time. I'm sure many have had no problems with the diesel but I bet most gas ones have less problems.
- jwmIIExplorerNo regrets. Shooda done it sooner.
- Big_KatunaExplorer III thought the no pass through was going to be something I wished I had but not crawling under the slides to get stuff is a good thing too. Your stuff moves out with the slide and the three connected bays accommodate everything just fine.
- rgatijnet1Explorer III
JimM68 wrote:
No regrets for us.
One thing on the Fleetwood, if it is important to you...
Many Fleetwood DP's did not have a raised rail chassis, and therefore do not have full passthrough storage.
You can tell if the basement doors come out with the slides = no pass through
Yes but many gas coaches, like my Monaco, do have large pass-thru storage so that is not something that is unique to DP's. If pass-thru storage is something you want, there are choices out there. - ValkyriebushExplorer II
Valkyriebush wrote:
JimM68 wrote:
No regrets for us.
That's correct. No pass thru on mine, but the three large compartments that come out with the slide connect together for a very long single compartment if you need lengh and want to use it that way too. I bet the Discovery is the same. - ValkyriebushExplorer II
JimM68 wrote:
No regrets for us.
That's correct. No pass thru on mine, but the three large comprtments that come out with the slide connect together for a very long single compartment if you need lengh and want to use it that way too. I bet the Discovery is the same. - ferndaleflyerExplorer IIITo answer the question-----NONE!
- JimM68ExplorerNo regrets for us.
You can tell if the basement doors come out with the slides = no pass through - w4phjExplorerI waited way too long to transition into a DP.
Maintenance takes a bit longer as now I have about
4 times as many zerk fittings to grease.
38,766 PostsLatest Activity: Jan 10, 2026
