- bullydogs1ExplorerWell, I got it in and it is working with an external powered hard drive...what a ***** as the small portable hard drive I thought would work did not...BUT, DISH has to enable it first..long story short...the person at DISH that did know what they were doing, walked me thru it and it came alive and credited back the 40 bucks for activation...Put the bigger hard drive up in the slot above wife's seat...barely able to fish thru USB cord to DISH box..that thing is tight in this floor plan...they later moved the location in SKQ style in 2010...thanks all, DW will be happy..
- AllegroDNomadIf your RV is stored on site and close enough to the S&B, you could try moving the Hopper to the MH and spread Joey's around the house. This could reduce you to 1 account. Drawback is that when the RV was on the move, house would have no signal, unless you downloaded the Hopper before it moved. May not work well, unless all are in the rv when it moves.
- dkreuzenExplorerWhen I changed to the Hopper system in the stick house the account only allows one standard receiver, otherwise you have to add another full account at full price. I had a dual receiver in the coach so I had to down grade to a 211k. When I set up the entire new package I asked if I could move my existing external hard drive from one receiver to another, and they said no problem. Well it worked when I moved it from the old DVR to the new Hopper DVR but when I went to move it to the 211k, it wanted to reformat the drive which will erase it. So I could not take my recorded movies to the RV.
I think my next move is to install a Hopper + Joey system in the RV. That way I will have three receivers, a shareable DVR, and RF remotes. I can add the new Hopper to the stick house system and copy movies to it then put it in the RV. - fredbonExplorerPortable automatic dishes are not compatible with DVR receivers.
fred - AllegroDNomadDon't bite to hard. You could lose a tongue.
I have Dish4MyRV (Pay as you go) account that requires specific receiver(s) & antennas. That's why. - BB_TXNomad
Gator48 wrote:
I am confused here
The Disk network VIP 211K is a single TV HD receiver without DVR. Are you saying you can connect an external hard drive and use this receiver as a DVR?
Where does the "DVR" software come from? It doesn't appear to be resident on the stock receiver.
Help please
Dave
I suspect the software is probably already resident in the receiver and they just send a signal to activate it. In any event if I remember correctly I just plugged the external hard drive in an a screen popped up on the TV with instructions to activate it. I seem to remember it provided a number to call to get it authorized. - Dutch_12078Explorer IIII've read that you can watch one channel and record another with a 211K+HD, IF one of the channels is OTA and the other on satellite. With your OTA antenna hooked up to the 211K of course.
- wilcoExplorerDepends on your needs/wants/usage I suppose. In my case, I had an available HD that worked. New features albeit limited, cost nothing. At the time, the real DVR was $399 where I live....now a much more "reasonable" $299! Still don't need it.
- zman-azExplorerI'll bite.
Why not just replace the unit with a DVR and be able to record and watch.
I will say the DVR is the top on my list for inventions in the last 20 years. If it did not exist I would never pay for satellite. - AllegroDNomadYou pay $40 to Dish for the ability to use an external HD as a DVR. They send the programming to your VIP211K. The VIP211K formats the drive.
Don't read into this. We are giving you our experience. I was told that it needed external power source but when I plugged in the Passport, the 211K powered it.
38,769 PostsLatest Activity: Apr 03, 2026
