rvcruiser's avatar
rvcruiser
Anyone have this problem? (long post)
Hello
Wondering if anyone can help us. A little background.
Fulltiming since 2006....first 4 years with a 37ft 5th wheel\f350 truck...then traded for a 35ft Winnebago class A. We have had work done on it..including the transmission rebuilt.
On our way between Florida and Toronto we had a nightmare trip. The rv temp was fine but when we slowed down for traffic or stopped for lights etc and then tried to speed up again, rv would not change gear...even when pushed to 55mph....usually changes at around 50mph.
Only by pulling over, shutting down and waiting for over 30 minuites could we continue. This happened repeatedly for 1400 miles. To make the nightmare worse, our emergency brake would not hold. So I had to get out on highway shoulder and put chocks under wheels. Terrifying and very dangerous as traffic and trucks sped by us!
When we arrived at our destination, even though the last leg was only a half hour drive in cool weather, the rv would not go into reverse until we waited over an hour. Then no problem.
We have been told, when we had the brakes done, that the autopark was fine.
We have to leave here for a 1200 mile trip and are getting more stressed as the time gets closer.
Does anyone have any idea what could be the problem\problems?
Thank you.
  • To make the nightmare worse, our emergency brake would not hold.
    Ditto on taking it to a Chevy Dealer.
    Call your local dealership and ask where their truck location is. Every town that has a Chevy Dealership will also have a truck dealer service department at another location in the same town. And yes they work on RV's and their rates are far less than an RV dealership.
    I am not sure on your make and model but on many the emergency brake is PART of the transmission. AND it also holds a large portion of the trans fluid.
    Been there done that. I had to have mine replaced at midnight at a semi truck service center. Because the service department kid at the last place I had it serviced drove it with the emergency brake on and lunched it. You loose fluid from the emergency brake component and you are loosing fluid to the trans.
  • Bruce Brown wrote:
    Transmission filter and fluid? Take a smell of the transmission fluid and let us know what you think.
    Will do that today.
  • First thing is to check the fluid level. To much fluid will cause problems not allowing fluid to drain back down properly. To little of fluid will cause aeration of the fluid. Possibly the filter has become lose or unhooked and sucking air. If electronic transmission could have a bad solenoid.
  • Transmission filter and fluid? Take a smell of the transmission fluid and let us know what you think.
  • Travelon wrote:
    Need more info. What year, what model, what engine?
    Oops....1997 Winnebago Adventurer chevy 454
