- I then pulled the rubber off to the side again, and continued to sand the drivers side of the roof.
Suddenly, I heard a sound like a "whoomp". I looked up and this is what I saw.
I was not sanding at the rear of the coach when it happened, I was still sanding on the drivers side. I just walked to the rear to take the picture.
Next picture is where it went...
Yup, just slid right off the passenger side, onto the scaffolding.
Well, might as well keep on sanding, because I wanted to sand the passenger side after the drivers side, anyway. - Today was really gorgeous. Sunshine, not too hot, not too cold, a slight breeze going, maybe 2 - 5 mph.
So, this afternoon, I pulled the roofing to one side so I could continue to sand the plywood on the roof.
It started off looking like this.....
After a little while a puff of wind came along, not very much of one, but a little increase, and at this point, I was suddenly looking at this.... Lol...
- Well, I did it.
I wasn't going to do it.
I should have not done it.
However, I did it.
Well, actually, I kind of didn't do it.
Say WHAT????
I let my wife talk me out of going out to work tonight.
As a result, I got nothing done today.
We had some other stuff going on, and we managed to get that done.
Then, we came home and sat down. That was a mistake.
Turned out, our get up and go .... got up and went! Lol...
Oh, come on, you've done the same thing. Lol.
So, tomorrow is another day. Maybe I can get up really early and work for a couple of hours before the rest of our day starts. ... Yea, right!
So, I hope to have an update tomorrow night.
Thanks for hanging in there! :) - I pulled the other side of the roofing back today. I worked on getting the seam ChemLink sanded off, well, ground off with the grinder and flap wheel.
I now have all the seams leveled off, as well as the ChemLink covering the screw heads.
In this pic the arrow is pointing to an area that I sanded with the orbital sander with 40 grit sandpaper. I did not wipe the dust off before I took the pic.
Is that all I did? Ah, yes. That took a couple of hours. It wasn't a 10 minute job, unfortunately.
Next move is to finish scuffing up the top of the plywood. I hope I can get that done tomorrow, but we'll see. Bruce Brown wrote:
Try using a flap wheel on your Ryobi 4-1/2" grinder.
Its crude sanding but fast and efficient. I took a little bit off a small section of plywood that way this weekend. Works well.
WELL, SLAP ME STUPID!!!!!! Never mind. It's too late. (already stupid). Lol...
For some reason, that thought never occurred to me. Duh. Lol.
Thanks for the idea. I did indeed try that, and it did work quite nicely, I might add.
This half of the roof is done, as far as the ChemLink goes. I still have some sanding to do on the plywood, to scuff up the Por 15, but the ChemLink is leveled out on this side. Scuffing the Por 15 will be a piece of cake with 40 grit sandpaper.
Using the flap wheel on the grinder, cut out a lot of time doing that. I plan on finishing the sanding tomorrow.
One more step closer to getting the TPO glued down.- Bruce_BrownModeratorTry using a flap wheel on your Ryobi 4-1/2" grinder.
Its crude sanding but fast and efficient. I took a little bit off a small section of plywood that way this weekend. Works well. - Continued my sanding on the ChemLink today. I finally finished all of the screw heads on the back half of the roof.
There are 2 full width seams on the rear half, which I haven't done yet. (red arrows). They will take a while.
Removing the ChemLink is taking a bit longerrrrrrrr than I thought it would. Surprise! Lol. Just like other things in construction - some take longer than ya think.
Hopefully, I can finish the back half tomorrow. Don't know if I'll get to the front half or not.
I have tried to remove some of the excess ChemLink by cutting it with a knife, and that does help some, but, it does not cut easily. It's still partially soft/rubberish, as I expected, and that makes it kind of difficult to remove. Brob wrote:
Glad to hear the scaffolding is doing its job.
REALLY glad to see you prepping for the roofing. I've been curious as to how the TPO was going to work for the rig. Keep us posted!
Thanks. I am also happy the scaffolding is working well. It's so much more of a pleasure walking from one area to another, rather than going up and down the ladder, and then only being able to access a small area at a time.
The TPO should work fine. One thing I noticed the other day after pulling the back half front. The underside is black, while the top is white.
After sitting in the sun for a while, the black side was hot to the touch. The white side, just a few inches away was nice and barely warm. That has made a big difference in the amount of heat transfer through the roof into the coach. Yay!!!- BrobExplorerGlad to hear the scaffolding is doing its job.
REALLY glad to see you prepping for the roofing. I've been curious as to how the TPO was going to work for the rig. Keep us posted! - Took a day off today. Just kicked back and relaxed a bit. See you tomorrow.
