- Bruce_BrownModerator
stripit wrote:
Now that was pretty smart to use that hole saw that way. I would never have thought of that.
I figured for a one time use, this would suffice. I only used mild steel for the extra cutting, and will probably never have a use for this size situation again.
It didn't take long to grind the angles and it worked well enough for what I needed.
Since I had coated the hole with Por 15 inside, the hole saw was a nice snug fit without wobbling around.- stripitExplorerNow that was pretty smart to use that hole saw that way. I would never have thought of that.
- Here's the final pic from the bottom with the drain just sitting there.
- Now you can see how this picture makes a little more sense. The drill was attached from the bottom and pulled down to cut the recess. I still need to put finish in the recess to make it water proof before use.
- Here is another view of the hole saw with the adapter I made. I also removed the drill bit that is normally used as a starting hole for the hole saw.
Since I was going to use the outside of the hole saw as my "pilot", there was no need for the drill bit.
- I originally used a 2 1/8" hole saw to drill the hole. As such, I cut a piece of mild steel roughly 3 inches long that would fit into the slits in my hole saw.
Then, I cut a taper on both sides, and both ends to allow for some clearance while cutting.
I then drilled a hole in the center of the steel and ran a screw in from the side of the hole saw to hold it in place while using it.
- Here is a modified version of the hole saw I used.
- I used a contraption like this. After all, if I am going to re-invent the wheel at every turn, well, lets get to it!
- Here's what it looks like with the drain just sitting in place.
38,767 PostsLatest Activity: Sep 19, 2016
