SpurHntr's avatar
SpurHntr
Anyone know where turn signal fuses/relays are located...
...in a 2008 Newmar Kountry Star 3916 Spartan MM Chassis?
Right rear blinker/lamp not working (right front blinker/lamp and right sidemarker lamp works with right turn signal actuated).
Left turn signal works fine.
I have previous pictures of the panel in the compartment below the drivers seat and don't see it in there, so I'm wondering if its in my drivers side rear compartment just in front of the rear axle where the latching 12V switch resides or hidden in the basement on the frame rail somewhere where my converter/inverter is.
Coach is parked a couple hours away from me at the moment so thought Id ask here to save me time when I get back to it....
Hoping it is just the bulb/connection at the lamp housing but haven checked that yet.
TIA
  • Executive wrote:
    If it were a fuse, neither would be working. It's either a burned out bulb, a corroded connection or a bad wire on that side....Dennis
    Thanks.
    Was thinking along same lines.
    Taking apart those tail lamps is less than fun.
  • If it were a fuse, neither would be working. It's either a burned out bulb, a corroded connection or a bad wire on that side....Dennis
