Dusty_R
Jan 15, 2023Explorer
enblethen wrote:
For information the bottom wire on the TANK for the sensor is common. The wires going up fare for levels. since all are lit, should indicates tank is full or the sensors are dirty, which is a common problem.
A test would be is to disconnect bottom wire and see what indicators do. If they all go out, dirty sensors.
Electronics tech in last sensor? Sounds almost familiar be a retired engineer from farther back!
It's been a long time but I changed ours to Sea-Level, which work very well, no false readings.
38,782 PostsLatest Activity: Sep 19, 2026
