Playtime_II
Oct 25, 2015Explorer
woundn't need the lube pump as they are for front wheel drive transaxles. You might need their driveshaft disconnect depending on the transfercase (i.e. can it be put into neutral). As for towing (weight) No problem but you will need some type of supplemental brake system. My 43' can pull 10k and still load the coach up to 45k. Most I have loaded up was for our move and fulltiming during the s&b search was 45k (coach and toad).
38,769 PostsLatest Activity: Apr 03, 2026
