- minimuttExplorerWe have a 5th wheel and want yo get a tire minder. We have bronze tire posts. Which minder should we get?
- RCMAN46Explorer
EsoxLucius wrote:
WesternHorizon wrote:
No, but what is the chance of that happening. I've driven probably several million miles over 45 years, never picked up a drywall screw, and have had only three flats. I also know that I will likely know that an inside dual has gone flat through the steering wheel, hopefully before it drastically affects the remaining dual. Maybe I'm due. It's your money though, spend it as you wish.EsoxLucius wrote:
Tire gauge and a rubber mallet.
Does that work when the inside dual picks up a drywall screw and goes flat over 10 minutes on the interstate.
It does happen:
My TPMS warned me of a tire going flat in time to safely pull off the freeway into a shaded area in southern Arizona on a 90+ degree day to put my spare tire on.
Without the TPMS I am sure the tire on my 5th wheel would have failed and often that results in significant damage to the 5th wheel. - BobboExplorer IIIIt happened to me in 2011. Drove home from Colorado Springs, CO with an inside dually absolutely flat. That is a little over 1,000 miles.
Not a drywall screw, mine was a nail. Before our next big trip, I had a TPMS, cheaper than a new tire or two. I was lucky, I had the tire patched, and it lasted until I replaced them 2 years later due to age. - EsoxLuciusExplorer
Does that work when the inside dual picks up a drywall screw and goes flat over 10 minutes on the interstate. - WesternHorizonExplorer
Does that work when the inside dual picks up a drywall screw and goes flat over 10 minutes on the interstate. - EsoxLuciusExplorerTire gauge and a rubber mallet.
- WesternHorizonExplorerI like TireTrakers which saved a friend from a blowout. See details in this post:
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/27901642.cfm - k9-kenoExplorerJust wanted to follow up with everyone on the Tire Minder. Traveled 2400 miles round trip with the Tire Minders and I have to say I am happy I bought them. We had a few false alerts but after understanding the product they were no big deal. We had two alerts because one tire was running 1 pound over what the computer considered acceptable. All I did was adjust the pre set tire pressure from 80 to 81 and this stopped. Had two no sensor readings this was because of two bad batteries that they will be sending replacements for. Also don't mount the booster to a 12v plug like it says not to do ( me not following directions ) because it jiggles free and can cause no sensor found alert. Last alert was when we were driving in 90 degree Florida weather and one of the tires was running about 5 degrees hotter than the rest. Again no big deal but its nice to know its keeping you informed. This device gives you great piece of mind and I must say it would help if you were going to have a blow out or ran something over long before it became a problem. Any questions let me know!!??
- k9-kenoExplorerOk I hooked up the tire minder 66 and it reads fine. Checks the tires etc etc. But the only question I have is the red light blinks when in monitoring mode....Is this normal?? Its not making any noises but the booklet does not say what lights if any should be on when just driving down the road.. Thanks
- BobboExplorer III
IAMICHABOD wrote:
Bobbo wrote:
Is the Tire Man Dually Valve Stems out of business? I bought a set from him a year or so ago and love them. I was going to recommend them in this thread, with a link, but can't find a working link.
Yes, Tire Man is still in business he has a new website.
Here it is TIRE MAN and Chuck is still there to answer any questions.
That's him!
Get tire valves from this guy and have them installed. Expensive, but worth it.
38,777 PostsLatest Activity: Jun 28, 2025
