wa8yxm
Feb 01, 2018Explorer III
You can google for RV DUMP Stations and then call ahead, MOST campgrounds ofer dump service as does Flying-J and selected other Truck/Auto plazas. And some rest stops along freeways but that is getting rare as .. Well some folks like to make life hard for others.
Appliances,, Stove, Fridgem Water heater Furnace.
Without make and model info I can not give SPECIFIC advice but I do have generic advice,, and some of them are kind of "only one set"
Starting with the fridge.. Three options here..
The fridge is likely a dual power (or tripple) 120 volt AC/Propane/(12 volt) I would not use the 12 volt setting. Deptnding on the mnodel the propane side will be either Direct Spark Ignition or some kind of manual pilot. I can not help you with manual pilot. DSI Fridges do the work for you
On ELectric Turn it onm let it sit overnight, should be cold tomorrow
On gas You need to make sure you have Propane, it is turened on and it lights
DSI units will have a FAULT indicator that comes on if it does not work.
I have neer seen a manual pilot so can not advise
Find the make and model then Google Make Model Manual
(Substutite the mnake and model numbers) these are often on the "Frame of the unit inside the Fridge door,
Water heater. Same google but different make and model
Manual pilot models you turn the knob to PILOT and either depress the knob or an assoicated Safety button while using a match or long lighter to iight the pilot. Hold button for 1 full minute after it lights.
MAKE SURE WATER HEATER HAS WATER IN IT beore doign this (Make sure water flows from teh HOT taps) Make sure the water heate ris not bypassed (nore in a second) once you are sure there is water in teh tank turn to ON.
Electric you sinmply turn on after making sure it's full of water.(Well mnostly full)
Bypass. One or two or 3 valves. OFTEN on the Rear (inside) of the water heater but somnetiems .. Well sometimes they put 'em in other places. YOu have a set of bypass Valves
The single vlave is a 3-way valve should be labed USE.Bypass (if labled) else USE points to the water heater
Two vlave is also 3 way if they point at each other.. It's bypassed point to heater to use
Three you want top and bottom open and center closed to use.
OVEN.. Oven is often just like the manual pilot water heater. Turn to PILOT or LIGHTm press and use a long lighter to light the pilot. hold for full mninute and turn to 350 or whatever settign Put thermomemter in oven and run for 14-30 minutesm take reading and adjust as needed, Mine is off 50 degrees.
Stove top.. YOU MAY have an ignition system or not, I use a lighter on one burner where the ignighter broke,, But then I always have.
Finally... There are two books you might wish to pick from (Either one no need for both)
The RV Owner's Handbook
The RV Book
Most larger RV dealers and Camping World will have one or the other.
Generic "Owner's manuals" for nearly all RV's. Lots of stuff that will NOT apply to you.. But also most of what you need to know.
The RV Book
