Ramair
Mar 01, 2014Explorer
if you have a heat gun you could remove the decals yourself and then have them install the new set and that should save a lot of money. Also call the factory and see if they have them and what the cost would be. Pealing decals with a heat gun is not that hard but time consuming depending if it comes off in big pieces or bit by bit. Have removed decals from 28' boats and the trick is heating.
