goose62075
Feb 12, 2014Explorer
aqua hot
What would be a guess at the life of the aqua hot system? I have heard pros and cons on a aqua hot system. seems like the guys that don't have them, speak the worst about them, and most people that ha...
RognBon wrote:I don't care what the coach builder does, the engine manufacturers dictate exactly what type of coolant goes thru their engines. And Aqua Hot specifically does not allow the use of a automotive type coolant in their systems. There has to be some type of heat interchange, but the Aqua Hot coolant does not go into your engine, and the engine coolant does not mix with your Aqua Hot coolant. I may not know anything about the Aqua Hot system, but I know that much.
I am not mechanically knowledgeable enough to explain how it works, or if it is the coolant or hot water, but I can tell you that it does. Perhaps not all coach builders provided this function, but it is included as an option in the owners manual which came with our coach way back in 1997.
