Olddud's avatar
Olddud
Are Engine and House Batteries Connected?
On a long trip home, after stopping to get gas, I turned the key to start, and the dashboard went dark. After a bit of panic in the 95 degree weather, I tried the "battery boost" switch, and feeling relieved, it started. I immediately assumed the engine battery was shot. Also, noticed the gas gauge now was pegged all the way to the right and way past "full".
I called ahead to a RV Park and stopped about 2 hours later. Got my voltmeter to check the engine battery, but the door automatic step didn't go down, so I assumed the house battery was now dead. Checked the engine battery with the engine off and hooked to shore power and it showed 6.5 volts, but didn't think about checking the house battery because it was late and I needed to get a new battery before the only auto store in town closed down. BUT, before removing the engine battery, I again tried the "battery boost" feature, and it did NOT start (but dash lit up), so the house battery must have been way down. Got the new engine battery and put it in, and all was well, except the gas gauge was still pegged to the right. Turned the key off and on several times in all directions, checked window operation, locks, etc., and somehow the gas gauge started working right again. Strange.
After thinking about it for a few hours, and worrying I fried the alternator somehow, went outside to check the voltage on the new battery without the engine running, and it was showing 14.5 volts! Checked it with the engine running and it showed 15+ volts.
Questions:
1. Why does, after 2 hours, the new engine battery show 14.5 volts without the engine running -- is it being charged by the house charger?
2. And, are they always connected in some way, or only when the "battery boost" switch is operated?
3. Why did I run down a brand new house battery? Western Kansas is a bad place to almost have a complete shutdown.
4. Have I ruined the new house battery?
By the way, I traveled 400 miles today and everything is working fine, charging right (checked it), etc.
I will check battery voltage on both batteries in the morning to see how they look.
  • I meant to say my unit is a 2010 Itasca Cambria 30C.
    Also, just measured the voltage after a night of no charge, and the engine battery was 14.3, and house 13.8. I would have thought both would be lower than that.
    I will do some tracing of the wiring to see what I might find.
    BTW, the engine battery was 7 years old! Something told me to replace it before the trip because my hi-tech charger wouldn't go into de-sulfate mode on it's own. It's one of those maintainer chargers that switches to de-sulfate after charging is complete. I actually think the battery shorted out in a place or two due to age, heat, and the gawd awful bumpy roads in Colorado, at least where I was driving.
  • If your engine battery was 6 volts or so and now a replacement shows 14 volts with the engine running, my vote is for a loose battery connection. It could be loose at the combiner solenoid or at the battery terminal. When you replaced the battery you tightened those connections but did you follow those heavy wires and tighten anywhere they are connected???
    The boost switch, if connected to the engine battery, would not close due to low voltage. If you get into a situation like that again, you can often just use one jumper cable between the positives to get things going.
  • Hi,
    You may have a bad ground. Finding it may not be easy. Check where the dash electrical system fastens to the ground.
  • Mine did that turned out to be the house circuit breaker.
    Also had to run a new trigger wire to the alt. That's
    after I replaced the alt. But now I have a 150A alt.
  • My thought would be a bad relay. I am no expert however. Let us know what you figure out please.
  • On ours, the house battery is charged by shore power, the generator, and the chassis alternator. The engine battery is only charged by the chassis alternator.
    This heat can kill a battery REAL fast. Traveling in 100% plus heat we've had to add water every other day!
  • Many have a relay that connects the two batteries together to charge the house batteries while chassis engine is running. Many use the same relay as the aux start.
    Make and model of MH would help.
  • I'm sure it can vary from mfr, but on ours solenoids connect two together under certain conditions. One allows engine alternator to charge house battery while driving. The other is the emergency boost moment switch if cranking battery is low and needs jumping from house battery. If plugged in and converter is charging house battery, it does not connect/charge cranking battery.
    I think I've listed those right...
