horsepower, the common unit of power; i.e., the
rateat which work is done. In the British Imperial System, one horsepower equals 33,000 foot-pounds of work per minute—that is, the power necessary to lift a total mass of 33,000 pounds one foot in one minute.
work, in physics, measure of energy transfer that occurs when an object is moved over a distance by an external force at least part of which is applied in the direction of the displacement. If the force is constant, work may be computed by multiplying the length of the path by the component of the force acting along the path.
torque, also called Moment Of A Force, in physics, the tendency of a force to rotate the body to which it is applied. The torque, specified with regard to the axis of rotation, is equal to the magnitude of the component of the force vector lying in the plane perpendicular to the axis, multiplied by the shortest distance between the axis and the direction of the force component.
HP = TORQUE x RPM ÷ 5252
So you can see that without torque you have no HP. HP is calculated, not measured. Moreover , if you don't have RPM you don' have HP.
Here is a good review of this.
Further think about electric motors in cars. At the moment of power application the speed is zero, there is no HP because there is no rotation of the motor. What moves the car at zero HP? Why torque does. The reality is they are very closely related and it is the application of the engine that determines at what RPM you want your torque and where you want your HP. So you want your 60000 lb MH to use 22.5 inch tire which determines your RPM. ~500 RPM equal a mile on your 22.5 inch tire. At 60mph your tire has 500 RPM.
Bottom line, climb hill at peak HP, to get best speed up the hill. Cruise at peak Torque for best fuel economy.
