OhhWell
May 08, 2014Explorer
I haven't and have never had a problem but... I really should use one. I have a hydraulic ram powered slide and the manual does say it is susceptible to slide creep. I guess the valve could go bad and let fluid into the ram.
Our coach has a key that must be used at the slide control panel to operate the slide motor. If I do start using a slide lock, I will attach the key to the slide lock on a hook or something.
