RonaldNC
May 08, 2014Explorer
My manual indicates that they are to be used if there is a problem with the hydraulic systems... that's why they supply them. In fact, Monaco only supplied one bar... even though I have four slides. I understand that other brands/models may differ.
I had to use them once and you need to be careful where you attach the bar to your slide. Unfortunately, when I had a blown seal on my ram, I used the bar and attached it to the inside edge of the slide... and it ripped the trim off the slide! Mine has a small metal ridge on the side of the slide (very strong) where the bar is supposed to be attached... lesson learned!
Ron
Ron
