dougrainer
May 08, 2014Nomad
wa8yxm wrote:
Your Fear is you will forget to remove it (Been there, Done that, No major damage, Have had to replace the odd shear pin)
My Fear is that the slide will extend when I make a right turn (Why I insert lock bar)
When Parked, as I am now, I store the lock bar inside the steering wheel (It stands up on the floor) makes it very hard to forget cause it is in the way of driving,, I also have a "STOP" sign for the antenna (Used to be called an Antenna Saver, I think they are back to making them now). It clips on either the wheel, or the ignition key.
Slide rooms cannot just roll out in a turn or such. A malfunctioning room may extend a few inches, but that is about the full extend they will go. IF YOU CANNOT PUSH IT OUT FROM THE INSIDE, THEN IT WILL NOT ROLL OUT OR EXTEND TOO MUCH WHILE TRAVELING TO CAUSE A HAZARD. Doug
