ArchHoagland
May 08, 2014Explorer
dougrainer wrote:
If supplied by the OEM, then they are required to be used.
1. Some are used to help keep the room from vibrating in transit(making squeaking noises)
2. Some are used to keep the room from slightly extending in transit
3. Some are used to pull the TOP of the slide in tight for a weather tight seal(Newmar in particular), but other brands as well. Doug
Good point on number 3.
I hadn't thought about leaks.
