ronfisherman
Oct 16, 2013Moderator
Induction cook tops are a good choice for a RV. Takes a lot less power than a electric burner and produces a lot less heat into RV. DW has a burner for the RV and a Range in the house that is all induction. Running a cook top on a 30 amp RV could be a problem though. Not enough amps to run a cook top and microwave at the same time. Same with AC and the cook top. Many of the induction cook tops have 1800 watts draw. You will not use it. Because it takes a lot less to cook. For pots and pans DW found a large selection at IKEA. At a very reasonable price.
Doing a quick search found these induction burners at AJ Madison.
38,779 PostsLatest Activity: Jun 16, 2026
