Hi,
It worked well for about 1.5 years and then started to trip. I do have the display inside and the temperatures are running higher.
tropical36 wrote:
pianotuna wrote:
Hi,
I have the ARP installed. It does work as advertised. However, my fridge is slowly going to fridge heaven and so I've wired around the ARP for now.
If I am concerned about overheating, I can put it back in the circuit by flipping one switch.
You shouldn't have to be doing that and if it's tripping out when it shouldn't be, try moving the sensor up higher on the tube.
