Old-Biscuit
Dec 24, 2017Explorer III
azdryheat wrote:
If the temp is forecast to dip below freezing I always disconnect the water hose and blow it out. I've never used one of those heated hoses but that might work.
I also have a water pressure gauge and I always check the pressure before I connect the water line. If it's above 50 I use a pressure reducer. Never have had a problem with city water.
Why not use that regulator ALL the time :H
Just because system only shows 50# when you checked it doesn't mean it will remain at 50#
I've seen system pressures drop due to demand and consequently have seen system pressures drastically INCREASE when demand goes down which can occur at anytime.
