doublevExplorerDec 23, 2017At what temp do you remove water hose?If the overnight low is 28F or 30F do you really disconnect the water hose outside? I am doing it now but am wondering if i am being abundantly cautious. At what temp do you disconnect outdoor plumbi...Show More
Blaster_ManExplorerDec 29, 2017Wrap the hose in heat tape (and the CG's faucet if necessary). Problem solved.
Related ContentWater pump?Staple RemovalWhy no hot water?fresh water hoseQuick connect exterior shower hose doesn't connect.
