Dale_Traveling
Mar 26, 2014Explorer II
It's a lot of work to replace an interior wall for a problem that with good maintenance shouldn't be a problem. Plus at 50 lbs. a sheet you're adding a lot of weight as compared to what you'll be removing. You'll need to more or less gut the coach interior to make the change. Unless you're doing a conversion project on a bus not sure it it's worth the effort or cost.
38,766 PostsLatest Activity: Jan 10, 2026
