localhost's avatar
localhost
attentive to standard interior walls
i becoming a full timer very soon with a customized coach from the start
i do not want to see the deliminate issue so i want some type of high strength plastic
http://www.parklandplastics.com/plas-tex.shtml
these are not a bad option they can come topped with a colored top coat the big issue with these is they have a massive thermal expansion and and at 3/8 inch they weigh in at 50 pounds per 4x8 sheet
using aircraft rivets and a sound proofing spacer on the stud and leaving a 1/2 inch gap filled with silicone or some type of gasket and covered in trim its durable but not ideal the bigger issue will be the mounting points they make aircraft rivets that will allow 1/4 in rivet to be installed into a 1/2 inch hole due to a large holding surface but this is not ideal it can be made to work but any better options exist that are designed for an rv that do not have delineating issue
i do not want to sacrifice a hot shower in fear of having the walls come apart on me but i want to also still have some options for decorative options no white walls with a choice of texture
    The delamination issue is seldom if ever on inside walls. It's separation of the exterior siding layers on composite-sided RV's.
