GjacExplorer IIIJun 12, 2015Attwood WH switch causing 15 amp fuse to blowWife took a hot shower fine, I tried but no power to the water pump. Found blown water pump fuse 15 amp and replaced it. It blew again and I had no lights above the stove for level readings. Found bl...Show More
icanonExplorerJun 12, 2015I would check for any loose wiring at wire connections locations and tighten them.
Related ContentSwitching toiletsAutimatic Transfer Switch?Battery switch causing heat upAutomatic Transfer Switch (ATS)Replaced landing gears and switch. Switch extends both ways
