Gjac
Jun 12, 2015Explorer III
DrewE wrote:I had a loose connection on the on off switch which I fixed, but it stil blows my 15 amp water pump fuse. I removed the fuse and checked amps which the hw switch on and it read 11.4 amps. I only have 10 amp max on my muti meter. 11 amps sounds like a lot to fire a propane WH.icanon wrote:
I would check for any loose wiring at wire connections locations and tighten them.
x2 — this sounds like a short circuit in the switched wire from the water heater control switch. If it isn't the wiring, it could be something with the water heater control board itself.
