Gjac
Jun 12, 2015Explorer III
wolfe10 wrote:. Wolfe I am puzzled also, I can't figure out if wires somehow got crossed just yesterday or what, but it has been wired the same way for 19 years and has always worked. I tried tracing the wire from the switch and from the fuse but could not see them. The fuse is only marked water pump.
Gary,
Those readings sound opposite to me. A typical 12 VDC water pump will pull close to 10 amps as it approaches cut-out PSI. More for larger pumps.
Also, I would sure separate the two functions-- power each from its own fuse.
I am also puzzled by what component of the water heater could be drawing 11 amps. The igniter only works for a couple of seconds. The gas valve should pull only a small fraction of that. Have you traced the wires from water heater switch to water heater to make sure you don't have a nicked positive wire?
