Gjac
Jun 13, 2015Explorer III
wolfe10 wrote:Thanks, that would be the easiest if I could just see a way to run the wire without it showing. It has to go from the left side to the right side. Right now it runs from the hood in back of the MW inside the wall and I think under the MH to the WH.
Rather than trying to find the problem with the hot wire from switch to water heater, just pull a new one. After disconnecting the old wire from the switch, check with a voltmeter to verify that it is indeed disconnected and leaving it in place will cause no harm.
