Gjac
Jun 14, 2015Explorer III
wolfe10 wrote:I thought I had it working it started fine and I took a walk around the campground and when I came back it was off. Thinking it came up to temperature and shut off I took a shower and it was only luke warm. So something else is wrong also. It would not go back on even when the hot wire was disconnect and reconnected.
Hope you have a fuse at the battery end of that wire! And, if you measure reasonable amperage, you know you have a wiring issue, not water heater issue.
While running a new wire may not be any fun, it will sure be less $$$ than a new water heater or major component.
