Gjac
Sep 27, 2019Explorer III
I would also check the circuit board and the connections to it. Atwood has on their web site how to check the board. I have had this same issue over the years ran a separate ground wire like Bud described, cleaned then replaced igniter, connector from 12v supply was loose and would cause an intermittent problem crimped on new connector, adjusted burner tube tip, and financially replaced board.
