mikestock
Jun 13, 2019Explorer
"m still holding out that something minor is causing the control panel not to light up. As my RR jack went into failure mode I turned the ignition off and on several times, looking for it to reset. When this failed I went down, pulled the RR fuse and replaced to see if this would reset it. After that, nothing worked. I replaced the controller module a few years back with a new one that Atwood supplied so I have the specific steps they require to install properly. The last two steps were critical, so I disconnected these two connections and replaced. No joy. I'm headed back out to take a fresh look this morning.
Interested in the cost of replacing the system with Big Foot.
38,769 PostsLatest Activity: Apr 24, 2002
