eadeal55
Jun 14, 2019Explorer
If anyone has an Atwood electric jack they want to get rid of, let me know. I have the 7500 lb ones on my Bounder.
I unintentionally pulled the micro connector off the back of the control panel when a rear jack alarmed a few years ago, and couldn't get it repaired or find a replacement anywhere. Had the jack's upper head rebuilt for $200, but without a control panel, there was no way to use them. Orange blocks became my friends.
A couple years later I'm sitting in a friend's '08 Phaeton, and realize he has the exact control panel I need. His on/off button was broke, so he called Tiffin right there and ordered a new one...$107 + shipping. His came in and it worked, so I had him order me one. That was Dec 16. Plugged it in and all 4 jacks worked and leveled as advertised. Worked OK for 10 months until the left front jack over extended and alarmed. Jacks would not retract so I had to unplug it (12v 2 wire plug at jack), spin the emergency retract nut, plug it back in and then they all retracted. Tried to use the jacks one more time after that with same results - over extended, alarmed and wouldn't retract. Haven't used them since. That was Oct 17...orange blocks are still my friends.
I was told that the jack is bad, maybe a flat spot on the motor, and I needed to replace it. Same friend with '08 Phaeton bought 2 new rear 15000 lb Atwood electric jacks from Tiffin late last year and installed them himself. I was going to have him check with Tiffin to see if they had any 7500 lb jacks in stock, but haven't got around to it.
38,769 PostsLatest Activity: Apr 24, 2002
